more boost with rs2 turbo
Hello!
The problem is that I'm seeing aprox 1.5 turbo boost pressure (2.5 absolute) all the way to 5500rpm and I can't get it to 1.8BAR. How could I resolve the problem and what's the limiting factor of boosting max to 1.5BAR? - can one get 1.8BAR with the standart WG spring. Do I need the stiffer WG spring (one from 034efi that says 1.9Bar max boost) or should I fit a MBC between the WGFV and WG and keep the stock WG spring? P.S. I have a 3BAR MAP so no worries about how the ECU could stick with these boost levels |
Programming?
