Question in regards of the power door locks..
so the drivers side doesnt arm the alarm. the passenger side and the trunklock does. hmmm... any recommendations ?
Bad microswitch. Both front doors and trunk lock should set the alarm with the key.
Same issue here, is the microswitch replacable?
Illustration 837-39 Item 3: 4A0 959 985 (left door), 986 (right door). It might just be a broken...
wire where the switch cables run out of the door to the body. Pull back the rubber boot and look for broken wires (worst case - the wire is broken inside the vinyl covering and you can't find it.)
I don't know the wire colour (its in the Bentley) |
Any chance you might be able to post the diagram?
No but you *might* get mail.
Thanks Dave.
