Go Back  AudiWorld Forums > Audi Models > Audi Original "S" Cars
Reload this Page >
Rear turn signal always on when headlights are on
Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Old 11-29-2018, 01:41 PM
Default Rear turn signal always on when headlights are on
Hey guys,
I have a '95 S6, manual tranny. Up until recently everything was working fine.Then my right rear turn signal bulb went out. I replaced it and the left one at the same time. Now they both work fine when the headlights are not turned on but when I turn the headlights on the right one lights up continuously and won't blink. The left one is still fine and blinks when it's supposed to. I've traded the left and right bulbs but the problem doesn't follow the bulbs. Could it be the housing that the bulbs fit into that is the problem? It looks to be just a collection of metal fingers to route the current to the proper connections on the bulbs so I don't know how that could have gone bad. Any suggestions? If I need a need housing where can I find one of those?
Also, any idea where the backup light switch is located?
kmessawer is offline
Old 12-02-2018, 04:23 PM
Weird rear light behavior is often traced to a bad ground connection. When you lose the ground, the tail and turn filaments end up being connected in series and weird stuff happens. I believe the backup light switch is on the tranny. About 90% confidence on that.
tigerwillow1 is offline
Jon Lin
05-13-2007 04:00 PM
neverfollow01
12-16-2005 04:22 PM
Hibiscus Hokie
12-22-2001 12:16 PM
Quick Reply: Rear turn signal always on when headlights are on
