What is the idle fuel pressure?
Doing some trouble shooting on the fuel system, and I noticed the pressure at the rail is well over 50psi at idle.
That's considerably higher than my other cars-- is it correct? Or do I have a regulator problem? |
I believe we have a 4.0 Bar Fuel Pressure Regulator, which is ~58 psi, so that sounds normal.
OK, thanks!
Originally Posted by GoHeels
(Post 24427302)
Often more importantly, under boost, fuel pressure at the rail needs to be 4 Bar (58 psi)plus the boost pressure, e.g. 22 psig boost = fuel rail pressure of 80 psig. Less than 80 psig, the injectors will run lean and you might have pinging issues. |
