Anyone enable active lane assist on their Q8?
Anyone with OBD11 figure out how to activate ALA on the Q8? I've tried everything for the B9 S4 and some codings are missing which I surmise is why I can't get it to work.
I have the hardware to enable this, but I haven't quite figured out how to configure the software to do just this! |
Originally Posted by angrypengu
(Post 25324366)
I have the hardware to enable this, but I haven't quite figured out how to configure the software to do just this! It works perfect. My Q7 had it and this one is even better. Try to follow the steps to activate Traffic sign recognition to see if that works. Be careful to backup your changes as there are many different codings in the forums. |
Originally Posted by aechazu
(Post 25324417)
I just enabled it on my Q8 (no driver assistance package) . I first used the same coding of the A4 forum and it didn't work. Then I was trying to activate the Traffic sign recognition ( that also didn't work ) and I might have changed something that made lane assistant work. Unfortunately I haven't documented all the changes I made.
It works perfect. My Q7 had it and this one is even better. Try to follow the steps to activate Traffic sign recognition to see if that works. Be careful to backup your changes as there are many different codings in the forums. You'd be the first, and I would be very appreciative!! |
1 Attachment(s)
Here is the log . You should be looking at the first part .
It was the first mod I did when I got the Q8 |
(Post 25324426)
It was the first mod I did when I got the Q8 Just reading through the log I do see you changing adaptations and some long coding. I do also see a bunch of long coding lines with an old value: and a new value: where there were changes in things like 07001563E0691CCD070E87089CFE9C38130B37110406009701 080A0019331601086308024010000000000303004308181802 000044010104000000000000000000 New value: 07001563E0691CCD070E87089CFE9C38130B37110406009701 080A0019331601086308034010000000000303004308181802 000044010104000000000000000000 Do you remember doing things like that? It might be an artificial remnant caused by OBD11 doing its thing, but just thought I'd ask! Thanks again! |
(Post 25324437)
Thank you. I am retracing your steps diligently and much appreciate this!
Originally Posted by jrjunior31
(Post 25324444)
All those crazy long codings you are seeing are generated by OBD after the much simpler changes that we make are saved to the car. Once the simple codings are saved the OBD app generates these long drawn out versions of the changes.
I've retraced his steps and will go try it on my D5 now! |
All cleaned up and got it to work. Thanks everyone!
For reference for your Q8s!: https://www.audiworld.com/forums/a8-.../#post25324491 @aechazu , so I can reverse engineer your steps for the traffic sign recognition, when did you get it to work? Nearer to today or nearer to the beginning? E.g. before or after ALA worked on your car? |
I never got the Trafic sign recognition to work. While trying I got lucky and got the active lane assist.
It's great that you were able to do it with all that mess in the code I sent . Please share if you get the traffic sign to work . |
(Post 25324509)
