Audi Q8 Discussion forums for the Audi Q8 SUVs
Audi Phone Box
Old 11-21-2018, 10:20 AM
  #11
Cadx6's Avatar
At least I was sort of right - apparently no RF amplifier - just capacitive connection to an external antenna.
Audi phone box
The Audi phone box with wireless charging connects cell phones to the car antenna wirelessly by near-field coupling.
This allows it to deliver appreciably better reception quality. The box also enables inductive charging based on the Qi standard, provided that the mobile device supports it.
The current flows from a coil in the base of the box to the receiver coil in the smartphone.
Cadx6 is offline
Old 04-03-2019, 01:06 PM
  #12
I have a new Q7 and had the same question. I called ATT wireless and they seemed to have no idea what I was talking about....tech support wanted to to call the connected car people to sign up for a data plan which was a completely different topic. Going to just leave well enough alone!
rc1991 is offline
Old 04-03-2019, 03:30 PM
  #13
LeicaNut's Avatar
It is not very difficult to complete. I just called Audi Connect customer service and they provided me with the serial number, part number and vendor. If you have AT&T, the Audi experience customer rep can register the phone box for you. I have Verizon, and had to call Verizon myself after the representative supplied me with the required information.
By the way, Laird is the manufacturer of the part and the FCC number is RK7MBC-NAR.
LeicaNut is offline
Old 04-06-2019, 09:07 AM
  #14
Thank you! I called and was able to get the serial number and the rep gave me the ATT website to go and register it. Pretty quick and easy!
rc1991 is offline
Old 04-07-2019, 06:20 AM
  #15
f10
And that website is?
f10 is online now
Old 04-07-2019, 07:52 AM
  #16
Apologies for this question. I'm so lost.
So I think the aerial antenna portion, based on research, is enabled via NFC. I bought the Phone Box for this function as I don't like wireless charging so have no intent to use the latter. If we don't register, are you saying that the aerial antenna feature doesn't work?
angrypengu is online now
Old 04-07-2019, 07:57 AM
  #17
https://securec45.securewebsession.c...albooster.com/
But you will need to call audi connect to get the serial number if you don't already have it. I had a card with the manufacturer and model number of the phone box already on it and then just wrote down the serial number they gave me and went to the website.
rc1991 is offline
Old 04-07-2019, 08:00 AM
  #18
Seems like you know a lot about this so will ask you if you don't mind. What happens then for folks not using AT&T for their cell phones? This point is moot, and thus the signal booster capability is useless then I presume?
Thanks
Old 04-07-2019, 05:38 PM
  #19
LeicaNut's Avatar
No, the signal booster will work, when you place the phone in the cradle.
You register the signal booster with your wireless carrier as pointed out in the owner’s manual. I have Verizon, and I called Verizon technical service to register the signal booster so I can use my phone with it.
LeicaNut is offline
Old 04-07-2019, 06:45 PM
  #20
Thanks
As Leicanut points out it will work with any carrier....I just happened to have AT&T. You do need to call to get the serial number and then call your specific carrier. AT&T just happens to have a website to register but I think you can call as well.
rc1991 is offline
Quick Reply: Audi Phone Box
