Flutter helicopter noise
1 Attachment(s)
Hi
have a noise on a 2021 Q8 with under 20k on it makes like flutter or muffled helicopter noise when in drive usually occurs after long drive say 75 miles and goes away if car is put in park i do have audio video but not sure I can post it here but will try |
are you using crossbars?
SCarGuy , Today 09:44 AM AudiWorld Super User are you using crossbars? not sure what you mean by using crossbars |
Originally Posted by Debp
(Post 25701182)
AudiWorld Super User are you using crossbars? not sure what you mean by using crossbars crossbars |
Shouldn’t matter if it does it when stopped right 😊
Originally Posted by jzhu625
(Post 25701195)
(Post 25701225)
You are so correct my sincere apologies
sorry. yes you can be stopped but as long as it’s in drive it still occurs but if you put it in park it stops sounds like something unhappy in transmission |
(Post 25701264)
It’s been there they replaced the brakes and drilled holes in the exhaust ( hacks )
The helicopter noise sounds like an exhaust leak most likely under driver or passenger side seat. Why did they cut holes in the exhaust?
