Garage Door Opener Problem
When i open or close my garage door with the lower display it always works, I have assigned the garage door control to the steering wheel button and it works fine except when I am backing out of the garage. Some times it works; some times it doesn't. It seems there may be a conflict with the camera system when backing up. Suggestions? Thanks.
The GPS setting that allows you to open/close the door from the upper display disappears when reversing in favor of the camera screen. As far as the steering wheel button that’s a shortcut which sometimes takes 30 seconds or more to load up so the button can get temporarily disabled. If you notice the lower display saying “initializing shortcuts” and none of your favorites are loaded yet the steering wheel button won’t work. I have Day/Night map set to steering wheel and it won’t change the map until all my shortcuts pop up on the lower screen.
Lmcgill
A6 (C7 Platform) Discussion
03-21-2017 05:06 AM
