Which Options in the manual are included
#12
Not exactly the same as the hold button on EU models or BMW, which, when activated, holds the car after braking whether it is faced uphill, downhill, or just stopped in traffic. If I have to activated by holding the brake pedal "several seconds," and contemplate whether I am "facing uphill" and to what degree to keep the car from moving, I might as well just keep my foot on the brake.
#13
Ok, I’ll look. I enabled hill hold on OBDEleven but it said “uninstalled” and I changed it to “installed”. But it probably won’t work, I’ve seen many other features with the choices being “active” or “not active”, which would be more promising.
#15
And the European version, including cupholder cover:
#16
What does the hill hold do different then setting the E-brake? …. ok in reading it sounds like they function the same just that the hill hold is automatic - it will engage as soon as you tap the brake at stop. So pretty much auto engage of e-brake sounds like. I wonder if the wiring is below the blank where you can install the switch and then engage it in OBDEleven.
I heard the cup holders are smaller in the covered version in Europe - US they removed for the larger cup holders. I noticed the ones in the back seat are ultra small.
#18
Something not expanded on much in manual I found I really like the other day - Smart Favorites.
I was going through and setting the XM stations I listened to as favorites so that I could just scroll through those from the steering wheel and virtual cockpit screen.
What I didn't realize was the "smart" part of setting them as favorites. Once set as smart favorites the car continually records those stations.
If I choose a station/song as I'm scrolling through, the song will start from the beginning no matter where it is live. You can also use the + and - Ribbon bookmark buttons to toggle back and forth between songs that have played recently (I don't know how long the buffer is but it had 4-5 songs back when I was playing with the other day).
Terrific feature that isn't explained much in the manual.
Also its in the manual but I missed - is that on the XM stations if you press on the station logo you get screen that allows you to switch between station logo and cover art as the default.
#19
Page 106 in the real manual describes the Hill Descent Assist function. Inexplicably it says it comes on cars optioned with Hill Hold Assist (which they removed for US so you just get the Hill Descent).
Sometimes I'm curious if Audi leaves off the Hill/Stop Hold in US as a lingering worry with the old "Audi Accelleration at stop myth"
RoyM
A4 (B8 Platform) Discussion
09-12-2008 06:21 PM
bsjd00
A4 (B7 Platform) Discussion
12-28-2005 09:22 AM
