Q8 Cup Holder cover?
#34
Thanks for the info and trailblazing! So - to several comments previous. Since the cupholder width is the same, question to Audi: the reason US cars do not have this feature OEM is because....?
#36
I can't figure out why. I sat in a A8 at the dealer the other day and it had the cover. Some people have said cost cutting but it seems more expensive to have different parts
#37
I just installed mine today! It was just as easy as the op mentioned. I personally took the risk of not entirely removing the console and bending it just enough to slip the replacement in after removing the original. Tools needed: plastic pry bar and small wrench / ratchet. I used pliers as I didn't have the proper size wrench to remove the 3 screws. One note, make sure the cover is opened fully before putting the unit, as there may be obstructions if you leave it closed prior to installation.
#38
Did you remove the gear ****? Did you pry it up from the rear lip? I assume there are spring clips holding it down, as after lifting high enough they disconnect? There is enough slack in electric connect , so you did not have to disconnect the gear and brake connection and were able to disconnect the 12V connector? Any pictures during the process?
#39
As for photos, no, I did not take any as it was really an uneventful process. Sorry. Can post finished photos if you like.
#40
