Q8 - OBDEleven
#71
This is a great thread. Thanks jrjunior31 for sharing your hard work!
I have started looking for codings that change the Virtual Cockpit - Consumption Display setting to display long term consumption memory versus the stock setting of short term memory. I will keep looking, but please let me know if anyone has figured that one out yet.
One comment to share with you jrjunior31. The "Fold mirrors by holding finger on lock sensor" is a stock setting that can be enabled in the MMI. No need for a change via ODB configuration.
- The mirror setting in MMI you’re referencing is Auto Fold mirrors at lock. This will fold your mirrors every single time you lock the car. But if you want to have more control over when the mirrors fold at lock you need OBDeleven. You un-check the auto fold mirrors setting in MMI and the mirrors will only fold when you specifically determine by long pressing the door sensor or the lock button on the fob.
Edit - I just realized you probably meant the Consumption display that shows the green bar moving. I don’t know how to change that to long term via OBD.
#72
The description is in the post you quoted. It enables the rear DRLs. So with Q8 you get the tail lights and the rear light bar on all the time. It also enables day time animation of the rear lights at unlock if you have the Matrix light option. Without OBDeleven the rear light animation when unlocking only works at night. This is one of the best codings for Q8 for sure.
#73
#74
Good question but if something goes wrong could change setting back and take it in under warranty. However if you plan to keep the car more than 4-5 years it may be a concern. Most people will buy an extended warranty in this case though.
#75
Things may be different in the US of course
#77
https://www.yourgamecave.com/oled-vs-led-lifespan/
#78
Certainly true for LED, but OLEDs do not last as long.
tomsti (10-24-2023)
