Q8 - Real World Fuel Economy
#51
You must have had a serious tailwind
Good Luck and I hope that sticks, you will be the only one I have heard in the high 20's and 30!
Perhaps you were heading down hill off the gas at that moment in time that you glanced down ?
So I just had my first road trip since I picked up my new Q8 last week. I did some testing at highway speeds for different MPH and noticed the MPG I'm getting is highly dependant on what speed your traveling at of course. Anyways these were for about 15 minutes each on flat Florida highways with ACC Standard set at 65MPH I was getting 30MPG, at 70MPH I was getting 28MPG, and at 75MPH I was getting 26MPG. My car has less that 500 miles on it so its brand new but thats what I was getting for MPG on the highway. I'll test again after a few K and see if it improves at all.
GeneBopp (06-27-2019)
#53
Last fuel tank MPG 12.63. It's not getting better for me. I have 5000 miles and learned to have to absolute baby it to get at least 16 mpg. Very slow acceleration, do not go above 70 mph, and no flooring or using dynamic mode. Sure if you are constantly on the freeway or light city driving it's most likely better, but I'm 70% city and usually 75 mph on highway. This is terrible.
#54
might want to manually check your mileage when you fill up record how many gallons you put in, reset he mileage counter and calculate it yourself. The trip computer mileage is way off on mine by about 2.5 MPG on the low side.
#55
Q
I calculate it as you mentioned. I do not use the trip computer for MPG calculations. These were my last MPG's from past 2 tanks:
14.5 MPG
13.6 MPG
This is suburban/city driving conditions. 90% city 10% highway. Rarely, if not never floored. Used Shell and 76 Gas. I am going to check all tire pressures as I can't imagine the MPG getting any worse.
14.5 MPG
13.6 MPG
#56
#57
Gas mileage Q8
Whatever you (or others) decide is the optimal pressure, I've found that +2 in the fronts (cold, of course) will improve the handling due to most Audi's (other than the R8) nose-heaviness.
We drive a LOT of highway miles and are already sneaking up on 3,000 miles (and we're expecting the "new engine" at 5,000 miles as per usual) and the trip computer registers between 18.5 and 23 based on several factors including speed and, recently, high winds. My guess is, at 5K miles, the mileage will be (in our circumstances) at least 22 MPG, but around town, the mileage really sucks especially if the transmission can't get higher than 4th gear. In our case, we will be changing the oil at 5,000 miles. Although hardly a direct comparison, our previous three Audis all had the V6T (or some variant) that is in the Q8 and my S4. The mileage improvement (and power improvement) is most noticeable starting at 10,000 miles. The Q8's heft (5,000+ pounds) seems to beg for the "mild" hybrid to be a bit less mild and a little more helpful, especially at the kind of speeds that are common in stop and go or slow and go traffic. My guess is THAT won't happen as the e-Tron foreshadows things to come (and I would assume will happen sooner once battery life can offer an easily repeatable 300+ mpg with ample power all the while.) There surely is some reason that Audi has decided to not go to either a hybrid or a plug-in hybrid which, I would assume, could get the range on a tankful of fuel (and charged batteries) to perhaps 600+ miles.
We regularly drive 100 miles one-way, and that really makes a "best case" range of 248 miles too close for comfort with respect to causing range anxiety (especially since charging stations are not -- yet -- plentiful. For us to drive from Cincinnati to Columbus we would have to find a Walgreens (they have charging stations at several of the stores in Columbus) and park there, plugged in. This makes little sense since parking at a Walgreens, unless it is located near our destination, is improbable especially since we would be stretching the "service" Walgreens is offering which is for a customer to charge while he/she is shopping in that Walgreens.
All the "energy" spent on promoting e-cars can't (currently) point to either great range (although it is pretty good, these days) or "widely available" charging stations.
Like everything else, e-cars (assuming they are the future of the automobile) should come down in price once rapid charging, pervasive availability of charging locations, and vehicle price fall in line with similarly capable petrol-engined vehicles.
At Costco gas prices ($2.59 for premium), a full tank on our Q8 yields a range of 515 miles to empty range, and a fill-up, even in the long lines at Costco, takes under 15 minutes. A super-charger takes 30 minutes for a reported 80% charge, which seems to me to be well under 200 miles to empty. The amount of oil, the cheapness of gas, the availability, etc., makes the Q8's thirst less of a financial issue than we've seen in some time. So, for the level of performance+luxury the Q8, nicely equipped for $80K yields, the e-tron is still a really hard sell.
If you're unhappy with the mileage of the Q8, remember that a lot of the world will be buying diesel Q8s and may not share our disappointment (assuming that is what we have) with the Q8's thirst -- of course, who's to blame for our not being offered a diesel Q8 (they dug their own grave, so to speak, in that regard).
Of course, if you're buying a vehicle that seems ready, willing, and able to have its price go north of $90K and its mileage is a problem, well you may find it difficult for folks to have much sympathy. Although I love our Q8, I have to assume it lists as high as it does "because the market is willing to bear it." "We've met the enemy and he is us," kind of thing.
We all want the Q8 to be a bit less thirsty, I'd imagine -- but, for now, count on a maximum, I would guess of 24 MPG (downhilll with a tail wind) and a normal MPG closer to 18-20 especially if you only drive "sometimes" on the highway in 8th gear. Dare I say, "first world problem?"
Have 7,600 miles on my Q8.. most highway. 20-21.5 MPG.. 515 miles per tank. Drove A8's for the last 12 years and averaged 28 mpg and a tank range of 630 miles. Driving in comfort mode both vehicles. Odd things happening.. wipers go on at will, back wiper radonaly goes on when backing up etc..
#60
Since I corrected the tire pressures, I did notice a better fuel economy in the same driving conditions. My past 3 tanks ranged from 14 - 16 mpg. I drove from the Bay Area to Lake Tahoe and back in the past day and on both trips, mpg stuck around 22 mpg. I drive around 75 mph or slower. This is about 3 mpg less than what I get with my Q7. Is the Q8 heavier? or is the new turbocharged engine just not as fuel efficient as the supercharged engine?
