Immobilizer bad actuator bad r-tronic pump
Hello everyone,
Long story short, the car will not start or turn over but I have full lights and radio and etc... I replaced the battery. There is a gear light and malfunction on the actuator and possibly the r-tronic pump. I do not hear is priming anymore when i open the door. Why can't I start the car and why do I have an immobilizer code? SEE BELOW: ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 420-910-156-V2.clb Part No SW: 420 910 156 H HW: 420 927 156 Component: SL600 5.2L FSI HDZ 0020 Revision: SBH02001 Serial number: 7MHN1523J Coding: 0000001 Shop #: WSC 06759 128 40452 VCID: 14644498378075EF25-8040 Subsystem 1 - Part No: 420 713 041 C Component: A11 C02 11.11.08 0A11 2 Faults Found: 005934 - Shifting Actuator P172E - 000 - Mechanical Malfunction - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 7 Reset counter: 255 Mileage: 110043 km Time Indication: 0 Date: 2019.05.23 Time: 20:27:23 Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min 0 Torque: 0.0 Nm Temperature: 21.0∞C 0.00 % 006079 - Hydraulic Pump P17BF - 000 - Play Protection - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 13 Reset counter: 255 Mileage: 110043 km Time Indication: 0 Date: 2019.05.23 Time: 20:28:23 Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min 2 Torque: 0.0 Nm Temperature: 21.0∞C 0.00 % ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 420 920 980 J HW: 420 920 980 J Component: KOMBIINSTR. VDO H02 0360 Revision: D0H02001 Serial number: AUX7Z0I2FNO0DX Shop #: WSC 00000 000 00000 VCID: 1C742CB8DF503DAF6D-8048 1 Fault Found: 16346 - Control Module - ROM Error 014 - Defective |
Whoever replaced your battery jacked things up. Sorry.
These codes were on there before the battery was replaced.
Still sounds electrical. That immobilizer module ROM error is an electric knife in it’s heart that would only be fixed by a dealer.
Agreed.
Now I have to find someone in the DC area that has dollies to tow this out of my garage safely... |
