Bad display, VW passat
My friends VW passat 2001, has a "bad computer display". Have a look at picture on the attached link.
Anyone knows what this might be. Is it the display that needs to be replaced, or is it some solderings points on the back of the display that needs to be resoldered ?<ul><li><a href="http://www.lundarvollen.com/slett/comp.jpg">Picture: bad display</a></li></ul> |
get someone to vag-com it - probably can be fixed by resetting some module.
Re: get someone to vag-com it - probably can be fixed by resetting some module.
I have VAG-COM, but can you explain the "resett" procedure ? There is no fault code logged.
I really would appreciate it if you could tell me what module to reset
