new problem.....
what is it??? how can i fix this.??
Get a new head unit with high (4V) line-outs
Get a line driver
Get a ground loop isolator (radio shack)
others too.
You can also try using one ground point for the entire system. This usually is not feasible due to the location of the various components.
You may also want to check to see if you have power lines running right along the signal cables. Sometimes this will cause you to "pick up" the alterantor whine.
