Panasonic CX-DP880 CD changer
Hi, everyone!!!
I have done plenty of research on CD changers for my '98 A4 with Delta Blaupunkt cassette deck, and the closest I have come to stock was Panasonic CX-DP880 CD changer. The problem is: besides the male 8-pin round plug, the CD changer also has 2 RCA plugs and constant power battery lead. I, personally have no idea where to stick the latter 3 cables. I was wondering if anyone has ever experiensed the same sort of problem, and if there is any solution to it at all. Sincerely, Alex. |
Yes you need the VAGT2 adapter that reroutes the RCA's back into the BUS cable
Unfortunately this has to be done at both ends so the adapter includes a HU plug and adapter for the changer.
If you click on the link below and select the VAGT2 under Audi.<ul><li><a href="http://www.icd-ltd.com/main.html">http://www.icd-ltd.com/main.html</a</li></ul> |
Help.
Thank you! I checked the link, but the adapters they have are ONLY compatible with "Concert" or Symphony" radios. I have a "Delta". They also talk about the 13-pin plug, I have an 8-pin. So, I'm still pretty confused.
