What is the proper / safe way to strip paint from calipers?
My calipers are currently painted, but I want to strip them clean and start over. I am worried about the rubber parts, etc.
Can you suggest products and methods.
Thanks!
Thanks!
By proper,I take it you will remove the calipers from the car and
remove all of its components,then proceed to sandblast them and then apply a quality epoxy paint or high temperature paint with a clear coat !!
If you do them by hand (non-sandblasting)
<center><img src="http://www.fototime.com/EFB9E344E6B108C/standard.jpg"></center><p>Brake cleaner spray, and an assortment of brass or wire brushes works pretty easy. At least it has on a few that I have done in the past. Brake Cleaner will not harm the rubber seals/hoses.
The picture shows a caliper that was stripped. I changed color from black to red.
Dremel with grinding and wire brush attachments works well.
The Dremel has plenty of grind to smooth the caliper surface and then remove anything that will get in the way of epoxy (or hi-temp paint) binding. I agree with S4Bloom, just mask carefully, use brake cleaner (not all are "rubber-safe"), and work slowly. Its actually a fairly simple job, and doesn't take too much time (apart from curing/drying).
USCTrojan4Life
03-02-2005 08:43 AM
koopS2
07-30-2004 05:40 AM
Gold A4 QT
05-19-2002 01:36 PM
