B8 s4 rotors stuck
B8 s4 rotors stuck
Trying to take my rotor off to get it resurfaced but it won't budge. Already tried wd40 and banging on... Complete caliper and carrier are off, any suggestions...?.
Its the worst! My B5 A4 had holes drilled for a set screw heres the genuine Audi/vw rotor.
Looks like the B8's have a hole drilled for them too.
If theres no screw installed, like you said a rubber mallet and some love should get them off!
Jason
Jason
Never Follows
If the screw is taken out give it a few hard hits with a hammer and get yourself some new rotors. I'm pretty sure it's not recommended to resurface B8 s4 rotors after going through a set of pads.
I don't think you'll have much more than minimum recommend spec after resurfacing.
If you insist on staying with the same rotors soak the hub with some PBblaster and give it a few minutes to penetrate. Then give it a few good hits with a mallet.
No need to replace rotors.
Agree - never resurface them ( i'll skip my long rant on why)
Try to hit them with something rubberized. You wont hurt the rotor any, but you could hurt the wheel bearing.
No one answer my question re: front or rear. Rears have the handbrake holding the rotor (but courtesy says answer the question anyway)
Put some anit-seize or grease on the rotor/hub mating point.
G
G
RangeR BoB
11
08-09-2010 09:38 AM
excellrec
Audi 100 / A6 (C4 Platform)
02-02-2009 06:53 PM
scfan
Audi allroad
14
05-13-2005 05:54 AM
808Guy
12-09-2004 05:58 AM
