Caliper heat shield
Hi, looking to get a set of these caliper heat shield - they are stainless steel, does anyone know the part number? thanks
https://cimg9.ibsrv.net/gimg/www.aud...1562fcdc63.jpg |
Those insert into the pistons it appears. Might reduce heat transfer a bit. I use titanium shims behind my track pads. Not a cure all but every bit helps. |
Thanks - I was hoping someone would know the part number on these.. before I did something different.
1 Attachment(s)
Here is a schematic that shows the part" #9 Heat Shield from an early A4, C54 brake system
What year A4? Could it be item #10 here? https://audi.7zap.com/en/usa/audi+a4.../6/615-615030/ |
Turns out I just made a set - very easy. They are .020 stainless, 2 /18" in diameter and the tangs are 1/4" wide and 3/4" deep. My neighbor had some .020 sheet and I cut them out with tin snips - simple heat shields! thanks for your help.
