Caliper heat shield - AudiWorld Forums
Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
Caliper heat shield
Old 10-29-2018, 07:52 AM
Default Caliper heat shield
Hi, looking to get a set of these caliper heat shield - they are stainless steel, does anyone know the part number? thanks
campbelllith is offline
Old 10-29-2018, 08:56 AM
J. Patterson's Avatar
Those insert into the pistons it appears. Might reduce heat transfer a bit. I use titanium shims behind my track pads. Not a cure all but every bit helps.
J. Patterson is offline
Old 10-29-2018, 09:10 AM
Thanks - I was hoping someone would know the part number on these.. before I did something different.
Old 10-29-2018, 03:36 PM
Here is a schematic that shows the part" #9 Heat Shield from an early A4, C54 brake system
Old 10-30-2018, 06:25 PM
What year A4? Could it be item #10 here? https://audi.7zap.com/en/usa/audi+a4.../6/615-615030/
Old 10-31-2018, 12:56 PM
Turns out I just made a set - very easy. They are .020 stainless, 2 /18" in diameter and the tangs are 1/4" wide and 3/4" deep. My neighbor had some .020 sheet and I cut them out with tin snips - simple heat shields! thanks for your help.
ArTT Vandelay
07-14-2008 07:09 PM
lax01
Off-topic Discussion
11
06-22-2006 10:27 PM
quattro_silver
06-10-2004 11:03 PM
audimods
07-24-2000 11:15 AM
Quick Reply: Caliper heat shield
© 2018 MH Sub I, LLC dba Internet Brands
