Interesting, lightweight S5 being tested
Whether it'll sell is another thing as Stadler mentions...
Translated from English, original German below...
Stadler to the Leichtgewicht Philsophie of AUDI
Stadler wants fewer weights
Rupert Stadler sets on consumption reduction by fewer weights. To TSI engine and 265 HP there are already one around 400 kilograms facilitated prototypes of the AUDI S5 with 2.0 During the reduction of consumption and Co2-Ausstoß AUDI does not only set on more economical engines. As chief executive Rupert Stadler reported automobile at the beginning of the salon in Geneva in the interview with the cars newspaper, consistent lightweight construction was to create additional potential. ,,We have the prototypes of a S5 finished, which weighs approximately 400 kilograms less, as the current standard model ", explained Stadler. In addition with chassis and body consistently high-strength steel and aluminum however only little carbon were used. Stadler: ,,Default was that the new car does not become more expensive than the current S5. " With the engine the eight-cylinder was replaced with 365 HP by 2,0 the TFSI engine from the AUDI S3, which carries 265 HP out. With the engine the prototype achieves the same acceleration values, as 100 HP the stronger standard model. The accurate values consumed were not determined yet, are however clearly under the values of the Serien-S5. Stadler: " Now we must test whether our customers accept a smaller engine also in this Fahrzeugklasse. "Optical are to differ both models hardly from each other.
In German
Stadler zur Leichtgewicht-Philsophie von Audi
Stadler will weniger Gewicht
Rupert Stadler setzt auf Verbrauchsreduzierung durch weniger Gewicht. Einen um 400 Kilogramm erleichterten Prototypen des Audi S5 mit 2.0 TSI-Motor und 265 PS gibt es schon
Bei der Reduktion von Verbrauch und Co2-Ausstoß setzt Audi nicht nur auf sparsamere Motoren. Wie Vorstandschef Rupert Stadler zu Beginn des Automobil Salons in Genf im Interview mit der Auto Zeitung berichtete, soll konsequenter Leichtbau zusätzliches Potential schaffen.
,,Wir haben den Prototypen eines S5 fertig, der rund 400 Kilogramm weniger wiegt, als das aktuelle Serienmodell", erklärte Stadler.
Dazu wurden bei Fahrwerk und Karosserie konsequent hochfeste Stähle und Aluminium aber nur wenig Karbon eingesetzt. Stadler: ,,Vorgabe war, dass das neue Auto nicht teurer wird als der aktuelle S5."
Beim Motor wurde der Achtzylinder mit 365 PS durch das 2.0 TFSI-Triebwerk aus dem Audi S3 ersetzt, das 265 PS leistet. Mit dem Motor erreicht der Prototyp die gleichen Beschleunigungswerte, wie das 100 PS stärkere Serienmodell.
Die exakten Verbrauchswerte wurden noch nicht ermittelt, liegen aber deutlich unter den Werten des Serien-S5.
Stadler: "Jetzt müssen wir testen, ob unsere Kunden auch in dieser Fahrzeugklasse ein kleineres Triebwerk akzeptieren." Optisch sollen sich beide Modelle kaum voneinander unterscheiden.
In German
400kg is quite a bit to shave off
Wondering if it's some lightened up version of the S5 ... like lighter seats, no rear seats, etc. etc. etc.
CUrious about the diff between the weight difference between the two engines.
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
Quattrings
01-17-2016 12:42 AM
Audi A6 2003 allroad 2.7t for sale in AZ
blackjulia
09-27-2015 09:37 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-24-2015 12:06 PM
