Question about rims
Will I be able to fit 5x112 19x8.5 rims, offset is 35mm.
Also, what size tire would I need if I could fit these on my car? Thanks |
For a B6, yes, it's fine. 235/35-19 is the tire size you'd want
Don't know enough to say anything about a B5 though.
Forgot to mention, this is for a B5, will it still fit?
235 35R 19's should fit at stock height.
You got a B5 A4? I use 32 offsets on my summers with 18's and I just barely rub at the front on dips using 225/40's...but I'm lowered about 1.75".
Well, I have coilovers on my car, and...
The car is lowered too. I have coilovers, and there is about a 1 finger gap in the back, and two fingers in the front.
Looks like you'll have to roll the fronts in that case...
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2166114.phtml">This dude using same tires with same offset</a></li></ul>
I dunno if it will fit . . . .
I run that setup on my B6 and it fits fine but the b5 guys usually stick with 18's. i have 19x8.5 rims w/ ET35 and i run 235/35R19 tires
you will have to roll your front fenders like i did i have 235-35-19 with 1 finger gap
it fits on a B5
Thanks for all your help guys!! Just bought...
myself a set of 19s today =)
Ill prolly need to learn how to roll the front fenders. |
