UPDATE: Front sub-frame modification (long)...
Well the front sub-frame mod was a lot harder to design and parts were a lot more difficult to produce and install... Glad it's out of the way now.
Big thanks to Ioan and Joel at TechnoArt for their hard work on this project. First there are three main parts to that sub-frame assembly in the front of our cars; the main sub-frame made of steel, the cast aluminium transmission cross member and the aluminium sway bar supports. All three had to be removed; the OE rubber mounts on the main steel sub-frame measured and tried to be duplicated in steel and on the sway bar supports and tranny cross member new aluminium hard mounts had to be designed and manufactured. All three mate together and are held in place by four main bolts and two other bolts for the sway bar supports. All have elongated holes so that the sub-frame can be move laterally to do proper alignments so we had to keep those in place to make it work properly. Basically the main sub-frame is sandwiched between the tranny cross member and the chassis in the rear and also sandwiched between the sway bar supports and chassis upfront. Making the “pucks” for the main steel sub-frame was pretty strait forward as in the rear sub-frame using the same basic design. They were welded in place with no second guessing. However when it came to welding the aluminium hard mounts that was another story. Basically we had to reassemble the whole assembly on the car, align everything as best we could on the car to make sure the new hard mounts were almost dead centre in their position so as to leave room on either side to be able to move and adjust the sub-frame either left or right as required for a proper alignment. When we were sure the assembly was in the proper position we went ahead and tack welded the aluminium hard mounts. The whole assembly was removed and taken apart. Then the new aluminium hard mounts were fully welded in place… What a PITA it was! The front sub-frame with the sway bar supports. Missing is the rear tranny cross member. http://i17.photobucket.com/albums/b7...July200901.jpg The OE rubber mounts. http://i17.photobucket.com/albums/b7...July200902.jpg We started by cutting their tops off. http://i17.photobucket.com/albums/b7...July200903.jpg Here’s one with its top cut off. http://i17.photobucket.com/albums/b7...July200904.jpg Then with the hack saw we cut through its aluminium centre. Then it was just a matter of punching it out with a hammer. http://i17.photobucket.com/albums/b7...July200905.jpg Here they are after their removal from the sub-frame. http://i17.photobucket.com/albums/b7...July200906.jpg The new steel “pucks”. Top view. http://i17.photobucket.com/albums/b7...July200907.jpg Bottom view. http://i17.photobucket.com/albums/b7...July200908.jpg Installed in the sub-frame bottom side. http://i17.photobucket.com/albums/b7...July200909.jpg Installed top side. http://i17.photobucket.com/albums/b7...July200910.jpg Test fitting once completely welded in place. http://i17.photobucket.com/albums/b7...July200911.jpg Here’s the aluminium sway bar support. Notice the “volcano” shaped mounting point. This of course would not fit with the new steel hard mounts so we had to redesign this part (same thing for the tranny cross member). http://i17.photobucket.com/albums/b7...July200912.jpg Close up of the aluminium mounting point on the sway bar support. http://i17.photobucket.com/albums/b7...July200914.jpg Here it is after removal of the “volcano” shaped portion. http://i17.photobucket.com/albums/b7...July200915.jpg Here’s its tranny cross member mount counterpart. http://i17.photobucket.com/albums/b7...July200916.jpg And now after its modification. http://i17.photobucket.com/albums/b7...July200917.jpg Here are the new aluminium pucks. Top view. http://i17.photobucket.com/albums/b7...July200918.jpg Bottom view. http://i17.photobucket.com/albums/b7...July200919.jpg Tack welded into place on the tranny cross member. http://i17.photobucket.com/albums/b7...July200920.jpg Close up. http://i17.photobucket.com/albums/b7...July200921.jpg Finally with it completely welded in place. http://i17.photobucket.com/albums/b7...July200922.jpg Also the 034 Motorsport solid aluminium transmission mount was installed. http://i17.photobucket.com/albums/b7...July200923.jpg |
