Re:
Old Nov 16, 2005 | 06:30 AM
appleboi's Avatar
New Member
Default Re:
Can anoyone help me remove the ding from the seatbelt light?
Old Nov 16, 2005 | 07:13 AM
JeffK (B6S4)'s Avatar
Member
Default heh, would you also like your airbags disabled?
probably not gonna get much help here . . . . just preparing you for a potential onslaught of responses telling you to be smart and wear a seatbelt.
Old Nov 16, 2005 | 07:27 AM
911eric's Avatar
Re:
Old Nov 16, 2005 | 07:28 AM
ReTodd's Avatar
Default Would you like the doors to lock and the windows to roll up in case of an accident?
Perhaps you can disable ABS and ESP?!?!?!
Old Nov 16, 2005 | 07:42 AM
520's Avatar
520
I cut of the piece that slides in the slot so its always there, minus the belt, and no beep :-)
Old Nov 16, 2005 | 07:51 AM
Shameless in Chicago's Avatar
Default Yeah but the warning beep is annoying even if you do wear a belt.
The new Audis are maddening. I wear a belt so I don't need to be told to. The worst part is when you are idling waiting for someone and parked, it dings every minute. I don't think I need to wear a belt when I'm curbside waiting for the wife. So anyway, I see the point in disabling the stupid bell.
Old Nov 16, 2005 | 07:54 AM
quattro_silver's Avatar
Default cut the buckle loose and insert it freely into the slot.
you can then use the remaining belt to hang yourself.
Old Nov 16, 2005 | 07:56 AM
appleboi's Avatar
New Member
Re: heh, would you also like your airbags disabled?<sub></sub>
appleboi's Avatar
New Member
Re:<sub></sub>
appleboi's Avatar
New Member
Re: Would you like the doors to lock and the windows to roll up in case of an accident?<sub></sub>
