Go Back  AudiWorld Forums > Regional & ACNA Discussion > European Discussion
Reload this Page >
ABS system funktion test "Not starting"
Old 07-12-2019, 08:47 AM
Default ABS system funktion test "Not starting"
Hi Audi owners
For the last months I have ben dealing with ABS and ESP problems. It accrued after I replaced the wheel baring and damaged the speed sensor. So after replacing the broken speed sensor dose the ABS and ESP lights glow. After reading the malfunction codes from the ECU with too scan tools, a Autel MaxiSys MS908S Pro and a Hex-net/vcds OBD reader, I get 01486, it says that the system function test Is activated. And that is correct, I tried to carry out a ABS system function test but I would not engage when I press the brake pedal down at a pressure of 45 bar.
Are there any Audi owners that knows what there is wrong?
PS. The car in question are a Audi A4 B8 from 2010
Best regards Jens
Jens_Mikkelsen is offline
audifirst
VAG-COM Discussion
12-07-2011 06:45 AM
Black Sunshine
12-07-2005 10:39 AM
Nova Scotia A4
10-21-2005 02:32 PM
Tept
07-04-2003 02:49 AM
Tom Barber
02-28-2000 10:29 PM
Quick Reply: ABS system funktion test "Not starting"
