Full solution for mutimedia conversion need: rip dvd, convert video, iPod transfer, i
If you have a portable devices such as iPod or iPhone, when you want to enjoy dvd, video on it, or want to transfer files from iPod to computer, or make an unique iPhone Ringtone, usually we need several conversion tools to do these work for us.
So now with the release of Aiseesoft DVD Software Toolkit, which is a perfect combination of Aiseesoft DVD Ripper and Aiseesoft Total Video Converterand Aiseesoft iPod Transfer and Aiseesoft iPhone Ringtone Maker, all of these work can be done with just one tool!
Now the following content will show you how to use this powerful program.
First: Install and Run Aiseesoft DVD Software Toolkit.
Part 1: How to rip dvd
Step 1: Select and Run Aiseesoft DVD Ripper and then click "Load DVD" button to load your DVD.
This professional DVD Ripper can load three DVD source, you can load your DVD from DVD drive, DVD folder in your PC and also IFO file.
Step 2:Select the output video format you want from the "Profile" drop-down list.
Aiseesoft DVD Ripper can rip your DVD to almost any video formats supported by iPod Classic, iPod Touch, iPod Nano 4, PSP, iPhone (3G), iPhone, Zune, Zune 2, Blackberry, Nokia, Creative Zen, Sony Walkman, iRiver PMP, Archos, PS3, Apple TV, Xbox, iPAQ, Pocket PC, Mobile Phone, etc.
Step 3:Click the "Start" button to start your conversion and In a short while it will be finished.
The editting functions such as "Capture your favorite picture", "Crop video", "Video Effecting","Trim video","Merge videos into one file" are also available and very easy to use.
Part 2: How to Convert and Edit video
Step 1: Select and run Aiseesoft Total Video Converter and then click "Add File" button to add your video.
Step 2. Output format and Settings
From the "Profile" drop-down list you can find one format that meets your requirement.
To have your own video settings you can click "settings" button.
After doing the 2 steps above, you can click "start" button to start conversion.
Tips
With the powerful editting function of Aiseesoft Total Video converter, you can crop, trim and change effect of your video.
Part 3: How to transfer video to iPod/iPod to PC/iPod to iPod
Preparation: Select and run Aiseesoft iPod Transfer
Step 1: Connect your iPod/iPhone to your computer via USB cable
Step 2: According your needs to select the the functions
If you want to import video/audio files to your iPod, click "Add files to iPod" button.
If you want to transfer iPod files to PC, click "export iPod files to PC" button.
If you want to transfer iPod to iPod, click "Transfer files between iPod" .
Step 3: After you have finished the above two steps, just follow the instructions on it to complete your demands.
Part 4: How to make your own iPhone Ringtone
Preparation: Select and run Aiseesoft iPhone Ringtone Maker
Step 1: Click "Browse…" button on the right side of "Input File" to import the file(audio or video file) that you want to make ringtone from it.
Step 2: Click "Play" button to listen the music to find the segment that you want to use it as ringtone.
Then drag and click the start & end slider to set your wanted segment, or type the start & end time in the corresponding text box directly to get the exact segment. Click "Preplay" to pre-listen the converted audio before generate.
Step 3: Click "Browse…" button on the right side of "Local Output Folder" to choose the output destination.
Step 4: Check "Export to iPhone" option, the converted ringtone will be load to your iPhone directly.
Click "Manage Ringtone" to edit the added iPhone ringtone by removing it or renaming it directly.
Step 5: After all the settings are finished, click "Generate" button to begin making your own iPhone ringtone.
It is really a wonderful experience to use this powerful software, so just have a try now!
Tips
chihashu
01-28-2016 05:59 PM
Touge.ca
Canadian Discussion
09-02-2015 01:30 AM
