Q7 Rear Lid Hatch Gate clicking will not fully close
Q7 Rear Lid Hatch Gate clicking will not fully close. All buttons on remote work and the button on the hatch operates, but when the hatch is engaging with the latch, the latch motor starts clicking and only pulls hatch down partially. The hatch is latched, but very loose. If I push against the hatch while the motor is engaging it seems that it latches a bit more and hatch doesn't appear as loose. But still an issue. Thinking of opening this motor/actuator and seeing what I find inside. Expecting to see worn plastic gears. This part is the Tailgate Trunk Lid Latch Lock Actuator Motor (Part 4F9827383B). I suggest outlining this part with masking taps prior to removal, as the bolts allow a good bit of play with installation. I suspected previous owner has already attempted some work on it, and some lining up might be in order so I didn't bother with tape.
https://cimg5.ibsrv.net/gimg/www.aud...0063144faf.jpg Drilled out the brads/rivets https://cimg3.ibsrv.net/gimg/www.aud...7985588af6.jpg I drilled out the brass brads/rivets. I did this while it was still bolted to the car. Once the rivets were nearly cut, I removed entire assembly from car using 1/2" socket driver, then onto the work bench. https://cimg9.ibsrv.net/gimg/www.aud...cef015cace.jpg To assist removing the rivets, using a #8 bolt (same bolts pictured below) I hammered the rivets from the top side where I had drilled into them, then pulled them out from opposite side using vice grips. Now motor/actuator is separated from the latch. https://cimg0.ibsrv.net/gimg/www.aud...ed2a03330b.jpg The worn threads marked. Basically, I lifted the gear up, rotated it counterclockwise until the worn area was just left of where it meets adjacent gear (small steel gear) After examining all the gears, you can see this is designed to fail. https://cimg0.ibsrv.net/gimg/www.aud...c821678ae1.jpg Worn area is in the 10 o'clock position. Remainder of gear is close to pristine. https://cimg5.ibsrv.net/gimg/www.aud...7c5827ee52.jpg The worm gear is steel, but the two brown gears are plastic molded to smaller steel gears. The larger gear has a spot with about 10% of the gears teeth worn away. Solution: lift gear out, rotate slightly, and reinsert so that the worn teeth will not be used during operation. The gear only turns about 1/2 turn for normal operation. It took 9 years to get this worn, so maybe we'll get a good many years out of this reassembled motor/actuator. I also greased the gears before reassembly. Closed the motor/actuator, reattaching it to latch frame with some #8 x 1 1/2" bolts with nuts. https://cimg1.ibsrv.net/gimg/www.aud...871765f125.jpg Installation reverse of removal. |
There is not much traffic on this board. You should post your question in the Q7 forum. There are many knowledgeable people over there. Good luck. |
