So who locally has upgraded their clutch/Flywheel? What Clutch/Flywheel?
And Can i swing by and take your car for a drive. I'm trying to decide what direction I want to go, but I'm just not sure...
SPEC Stage 3 with LWFW 80K miles NO Issues...Believe it or Not.
I can reccommend them highly, but others will Scream no. I do not reccommend the LWFW for 1.8t cars the lack of resiprocating weight and no real torque makes for a hard starter.
Once your moving its no issues, but getting started in most street situations is a chore.
If you have less than 350 Bhp I would highly reccommend the SPEC Stage 2 Clutch and STOCK Flywheel. If you Road Race every weekend then maybe the LWFW.
GatorAl just did a new RS4 setup and LOVES it. S4 though.
whatever you do, DONT GET A LWFW
just assume it will rattle and sound like a diesel. thats what mine did. cost me a thousand bucks to replace it. plus it gets really easy to stall in city driving, especially in traffic.
I have run a LWFW for 80K+ The rattling noise is from transmission...
I have run a LWFW for 80K+ The rattling noise is from transmission preload and is completely normal for a LWFW. The noise comes from the factory tolerances for preload for a 40+ lbs fly. When you remove 30+ lbs from the load it alows the gears to rattle a little because there is no "Built in" load. It does not hurt anything and can be fixed with a slightly heavier cold lube. Like instead of a 5/90 use a 10/90.
If you install a LWFW you will be able to drive much better at track events, because rev matching is like cake baby cake.
If runoverB4 replaced his fly because of noise alone then i fear he wasted $1000.00. Of course if you hated the way it drove to then.
This link is to my sight for clutches. Read the descriptions for better clarifications.<ul><li><a href="http://www.tunerswarehouse.com/pages/spec-info.htm">http://www.tunerswarehouse.com/pages/spec-info.htm</a</li></ul>
CupertinoS4
07-02-2004 03:01 PM
