Forge 007 springs
Old 04-10-2013, 03:18 AM
vtraudt's Avatar
Default Forge 007 springs
What are the signs or symptoms for running a diverter valve like the Forge 007 with a spring pressure that is too low or to high?
Say standard spring 5-15psi, but actual boost is 25 psi?
Old 03-10-2014, 05:29 AM
vtraudt's Avatar
Potentially, the DV valve closing force (spring force plus boost pressure times piston area at vac line connection)
could be LESS than
force from boost pressure times piston area at the line from high pressure side)?
Michigan TT
10
07-28-2008 05:22 PM
adminisTerTurbo
Audi Original "S" Cars
04-28-2008 06:22 AM
ottomann
10-03-2003 06:13 PM
back2black
29
04-23-2003 09:12 AM
Quick Reply: Forge 007 springs
