2.3 distributer can't get it out heeeelp
Old 01-08-2012, 03:08 PM
joshstaygold's Avatar
Default 2.3 distributer can't get it out heeeelp
iv got a 92 80q with a 2.3L im trying to pull the ditributer out and there is a lever hook like piece holding it flush to the block. its not bolted on but riveted. how do i get it to move so i can pull the distributer out???
thanks!
Old 01-25-2012, 10:13 AM
x19
x19's Avatar
I think that I used chisel if my memory were wright and used WD-40 for lubricate to base of distributor.
Clamp the above base with vise-glip ( don't tight) and knock the end of v/glip with small hammer one way or other way. x19
Old 01-30-2012, 08:28 AM
So your saying to use a chisel to take off the rivet that's holding the piece that's holding the distributer flush? If I do that is there a way to put it back on when I replace the distributer?
Old 03-18-2012, 05:41 PM
Razor B's Avatar
The rivet is holding a cover that covers an adjustment bolt. The cover keeps you from adjusting the timing, because Audi doesn't trust you to make those kind of adjustmens. If you trust yourself to make those kind of adjustments, place a thin chisel at the base of the head, like you are trying to cut the head off of the rivet, and you should have it pried lose with a few light strikes. You will then have to loosen the bolt underneath to adjust or change the distributor after throwing away the rivet and cover.
SimianSpeedster
TT (Mk3) Discussion
15
01-05-2017 02:28 AM
Quattrings
01-17-2016 12:42 AM
dorschman
09-17-2015 03:24 PM
KNICKSnKICKS
S6 (C7 Platform) Discussion
08-29-2015 07:49 AM
KNICKSnKICKS
RS 6 Discussion (C5)
08-28-2015 12:06 PM
Quick Reply: 2.3 distributer can't get it out heeeelp
