95 S6 won't run
95 S6 won't run
Started to run on 4 intermittently. Finally stopped running suddenly. No check engine light. Fuel pressure OK. Timing & belt OK. Compression OK. No VAG-COM indictions. Found bad coil. Changed it. No start.
Only two plugs firing. Found bad power amps. Replaced both.
No start. (Maybe on one or two cylinders) Wiring OK.
ECM??? or ?
Ed B
ECM??? or ?
Ed B
No distributor on S6
My guess is crank position sensor, then cam position sensor.
Post the question up on the original S cars forum here, and you'll get more responses too.
bar1
Audi Original "S" Cars
01-27-2006 11:41 AM
3fordasho
07-22-2005 12:45 AM
