HELP!! Massive fuel from single injector during fuel pump start
I am fairly new to this great site. I have a 10V I5 with CIS KE3 Jetronic. After sitting for several months, it is spewing large amounts of fuel from a single injector whenever the fuel pump is running. I checked the other 4 injectors, and they are funtioning normally (Spray only when sensor plate is moved). I swapped the apparent bad injector with one of the good ones, and the injector which was put in the spot where the wierd praying occured was no spraying during fuel pump running. So apparently it is not a bad injector, but rather something with the fuel control system. I did notice that 4 of the five ports on top of the fuel distributor have a restrictor in them. I purchased a fuel distributor from the salvage yard, and it has restrictors in 4 of the five spots. Any help would be greatly appreciated.
Thanks,
Matt
Thanks,
Matt
No Bozos!
Clarify
When you put a good injector in the bad spot the problem stopped?
""I swapped the apparent bad injector with one of the good ones, and the injector which was put in the spot where the wierd praying occured was no spraying during fuel pump running""
Based on that statement it sounds like it IS a bad injector.
DRennick
Misc. Models Discussion
07-25-2002 12:36 PM
