Let's settle this VR5/VR6 thing once and for all!!!!!!!
Vr6's and Vr5's Crank pins (or "throws") are "offset" by 15° to compensate for the 15° V angle of the block.
So a Vr6 is actualy an inline six (pistons 1 and 6, 2 and 5, 3 and 4 reach T.D.C. at the same time causing even firing pulses).
Same theory goes for the VR5 (except the pistons idividualy reach T.D.C. every 72°).
In the pic below, if you look at the crank throws (1 and 6 for example) they are just BARLEY offset....
<img src="http://www.eurospecsport.com/Images/engines/vr6crank.jpg">
NOW, I bet you guys didn't know this, but the Audi V6 is a 90°V instead of a 60°V (the way it should be to create even firing pulses), so in order to compensate for the "incorrect" V angle, the crank throws are "offset" by 30° enabling 2 pistons to reach T.D.C. at the same time!!!
My guess for using the 90° angle is for compact packaging and a lower hoodline.
See pic below, and you'll see what I mean!!
<img src="http://www.eurospecsport.com/Images/engines/!v6crank.gif">
Compact packaging?
The height of an engine is rarely a problem. It's the width that usually matters. That's why VW uses the VR6 instead of the V6. Because the VR6 has the small angle, it can fit into a GTI or Jetta the wrong way (transversely). If you try to put a V6 in there the wrong way, it'll be too wide.
sdb90
20
12-24-2007 09:21 AM
What is an offset? I know audi's are 35mm. What does it mean when they are higher or lower than 35mm
WickedA4
04-30-2003 07:17 AM
CasaS4blanca
04-22-2003 06:08 PM
Crazy Ivanski
03-10-2001 06:39 AM
