NEED HELP WITH COUPE GT!
Hey everyone, I've never posted on here because I’m usually able to find everything by searching the threads. But now I can't find any info and at the end of my rope! I have an 85 Coupe GT with a 2.2 I5 KX engine at 120k miles. It has a miss and runs rough through the rpm range. I've replaced cap, rotor, wires, plugs, distributor vacuum advance, ignition coil, vacuum lines and all five fuel injectors. fuel pressure is good and just today I got the engine up to operating temp and did a cylinder compression test with the following results: #1-110psi #2-105psi #3-105psi #4-110psi #5-95psi. So are these #'s normal? Any ideas? Thanks
Originally Posted by 1985_GT
(Post 24507201)
