Repair harnass for multi function temp sensor?
Hello all,
I the wiring at my multi function temp sensor is in need of some work. I havent pulled the boot off completly yet, but theres definately some broken plastic in there. I thought I had seen a repair kit for the harnass some time in the past, but did some quick searching and came up empty. Has anyone else seen or heard of this, and whre can I get one?
Thanks in advance!
Thanks in advance!
034 sell the kit , I bought it but before that I just wired it with separate spade connectors and ..
034 sell the kit , I bought it but before that I just wired it with separate spade connectors and it worked Great , just write down the order of the colors if you do it that way if not here is the 034 part
http://www.034motorsport.com/product_info.php?products_id=759
1 x Connector Repair Kit, Multi Function Temp Sender $19.50
Re: Repair harnass for multi function temp sensor?
SJM Auto sells what you need, I had the exact same problem and they sent me the connector, pre-crimped with wire tails, and crimp connectors to wire it in, for $12
egp320i
08-29-2008 06:48 AM
5000SLine
06-28-2008 04:33 AM
salpinx
9
08-05-2005 02:21 PM
