For those with stock IMs and the aluminum bits everywhere:
Old 10-28-2004, 12:28 AM
snowman '92 100's Avatar
Default For those with stock IMs and the aluminum bits everywhere:
Yes, I know this is 2.8 v6, but take a note
Simple work and it looks very purdy!
<img src="http://www.lightworksmediagroup.com/images/petes/metal/Image2.jpg" />
Old 10-28-2004, 04:59 AM
fusilier's Avatar
Default Does that take off any beading detail in the casting or is it just a cleaning with no detail loss?
I like the rough cast look over polished.
Old 10-28-2004, 05:27 AM
Member
EvanUrS4's Avatar
I like that a lot... what exactly are you using there? Looks like fine steel wool?
Old 10-28-2004, 10:48 AM
AudiSport4000's Avatar
Default I wouldnt mind trying that on my MC manifold...
Any info on what brush that is and where to find one? Im sure I could just use a regular ol drill??
Mike
Old 10-28-2004, 12:33 PM
Shavedquattro's Avatar
Default Why not get it bead blasted? It comes out lookin so purdy, and it takes less time..
Unless a blaster is not accessible, or you don't want to take the manifolds off i suppose. I did it with the 4k IM i put in, and it sent me on a Bead blasting frezy.... wastegate, brackets even bolts...
Either way is purdy though
Hank
Old 10-28-2004, 02:01 PM
Blake@NWAutoSalon's Avatar
Default When I did it, the texture was still there. I dont think a steel brush attachment could take down
the rough cast.
Old 10-28-2004, 05:05 PM
Default Manifolds are off the motor...
I may look into something like that next summer when I start to prep the motor for install. Im on a college budget, so we'll see how much "bling" the engine bay gets.
Mike
Old 10-28-2004, 06:39 PM
cuatrokoop's Avatar
Default I just prepped and then painted mine...Silver 500 or 1500F engine paint topped with 500F clear coat.
And I took the time to give the turbo script a machined look.
It'd look killer in black (krinkle, ala Derek's car) with the "machined look" turbo script....
Old 10-28-2004, 07:04 PM
Default Yours looks professionally done...
I guess I was wrong, I figured you had something special done to it
Paint would be a good idea, what kind of prep work are we talking about here for the manifold?
Mike
Old 10-29-2004, 02:20 PM
B2119's Avatar
Is that just the bit/brush, or is there anything on it?
Quick Reply: For those with stock IMs and the aluminum bits everywhere:
