1993 100CS Quattro Engine Temp Problem
Old Jan 17, 2001 | 05:09 PM
srg3037's Avatar
Default 1993 100CS Quattro Engine Temp Problem
About 1 year ago my thermostat failed resulting in overheating and subsequent head gasket failure.Head gaskets, waterpump and new thermostat installed......however since that time the engine has twice overheated in traffic when the fan has failed to come on...I have forced it on by turning on the compressor and the car is fine. I thought the problem was with the fan switch located in the radiator but, diagnosis says that the radiator is only getting to 130 degrees when the engine is ready to overheat and therefore the radiator temp switch would never come on......Repair place who I marginally trust says the "new" thermostat is bad e.g. only partially open and must be replaced (Approx $150.00)......The thermostsat is effectivly brand new....does this make sence???? Any other ideas or thoughts????Thanks for your help....Dick
Old Jan 17, 2001 | 06:33 PM
ChuckH's Avatar
Member
Default It's possible and fits the profile, but $150? Even for the V6...
...that can't be right. Thermo should be less than $20 and you can probably replace it yourself if you are even marginally mechanically inclined. Sorry, I don't know where it is on the V6.
Old Jan 17, 2001 | 06:35 PM
ChuckH's Avatar
Member
Default Also could be radiator blockage, but at <$20 and half an hour of...
...your time (atleast on the 5 cylinder cars), the thermo isn't a bad place to start.
Old Jan 17, 2001 | 07:02 PM
DavidFeygin's Avatar
New Member
Default Getting to the Thermostat...
is a bear on the V6-12 valve. You have to remove and re-tension belts, etc. Not at all easy. My pretty good mechanic took about 2 hrs to do it. But in any case, it should be much less than $150 for the part itself.
Dave
Old Jan 17, 2001 | 08:14 PM
QCRAZY's Avatar
Default Pic of thermostat in 12v V6.....
...it's a little nasty to get at (it's near the t-belt). Not quite as nice as the 5cyl!!
BTW: It's labeled as (1)
<img src="http://pictureposter.audiworld.com/1889/thermo93.jpg">
Andrew
90 80q
91 90
95 90q
Old Jan 17, 2001 | 09:47 PM
ChuckH's Avatar
Member
Default Eeeewwww!!! Now it's all clear. Leave it to Audi to put an...
...inexpensive and common failure item in a PITA spot! And all the times I swore at my 5 cylinder for being a PITA!
Old Jan 18, 2001 | 01:37 AM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Thermostat CAN be R&R'd without messing with timing belt! BTDT! Several times..........
Yanivic
Jul 1, 2008 02:55 PM
audiparents
Audi 100 / A6 (C4 Platform)
Jun 9, 2008 11:46 AM
TEB
Jul 1, 2006 11:47 AM
highlyaspir8ed
Jun 30, 2005 06:42 AM
kjell
Mar 3, 2002 06:17 AM
