Arg, another problem arose today..
Old Apr 26, 2001 | 04:32 PM
Style12v's Avatar
Junior Member
Default Arg, another problem arose today..
Posted this to the 12v mailing list, but was curious if anyone here knew what was going on..
"yikes, my check engine light came on today
so I pulled over and noticed that EVAP Frequency Valve was pulsating
rapidly.
After a few min, it stopped.. so I started the car again, and about 2-3 min
it came on again and sure enough the EVAP frequency valve was pulsating
again.
Turns out, that after afew min the Whole valve starts pulsating like crazy,
and stops after another 2-3 min. Obviously this is linked the emission
control, so I felt it was safe to drive home... but I would rather not cause
any perm damage.
Anyone have any clue what is going on? My guess is something wrong with the
connector or something, and my exhuast is probably pretty dirty...
Anyone who has a bently manual, or have any insight?
Thanks in advance
Old Apr 26, 2001 | 05:24 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Re: Arg, another problem arose today..
EGR system not functioning properly.
Could be the EGR valve itself, or its vacuum hose's, or the temp sensor for the EGR.
More than likely its the valve.
Style12v's Avatar
Junior Member
Any known way to fix other than replacing it? :\
Old Apr 26, 2001 | 05:41 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Re: Any known way to fix other than replacing it? :\
The passage in the intake manifold can be cleaned
if clogged. The EGR valve can usually be cleaned
if clogged. Most of the time the EGR's rust and stop functioning.
Old Apr 26, 2001 | 10:49 PM
®ob's Avatar
A lot of times vacuum lines fail. Those are cheap to replace
Old Apr 27, 2001 | 05:16 AM
ARK's Avatar
ARK
Read out the DTC code, to troubleshoot.
krsmith
Nov 13, 2011 01:47 PM
Mr. Head
Mar 28, 2009 01:26 PM
ivialb21
VAG-COM Discussion
Jul 18, 2008 04:59 PM
Petemic
Audi 100 / A6 (C4 Platform)
15
Jul 15, 2003 09:03 AM
