brake fluid/bleeding question
Thanks,
Brian
Follow the instructions that should come with your (Speedbleeder?). Always bleed from the furthest caliper from your reservoir to the closest. In other words, bleed in this order (probably) RR, LR, RF, LF.
Don't forget to periodically refill the brake fluid reservoir, while you are bleeding. Don't let it run dry or you will have to start over.
HTH,
