Climate Fault Codes
11.7 - Central flap, Sporadic block
15.1 - Air flow map motor potentiometer static open.
Any Ideas how to go about fixing this?
control unit needs to be replaced(~$500), not sure I trust that one or it was worth it.
Also, out of curiosity sake, what's not working? On mine it the rear central vents.
Jim
connections. I'll also rmove the glove box and see if I can't get back there and find the flaps.
I had a similar problem with my volvo which ran totaly on vaccuum pressure, this sounds electrical but if theres a physical blockage I may be able to find it.
Thanks Again
Sam.
