Engine dies cold at 75 MPH
Old May 6, 2000 | 04:36 PM
Dutch's Avatar
New Member
Default Engine dies cold at 75 MPH
or even higher speeds, on my 93 100S with 124K miles. It's just like someone turned the key off; the engine stops, the dashboard idiot lights come on, and the check engine light flickers.
Wait 20-30 seconds, turn the key, and it starts right away. As you can guess, at these speeds, I'm still coasting in many cases, if on a incline, I may have to pull on to the shoulder.
Driving from DC to St. Louis yesterday, this happened 8-10 times, until the cooler temps in the evening, when it ran good. This happened last summer, too, always in hot weather, never in the winter.Two dealers could not fix it; put in fuel pump, pump relay, and downloaded fault codes; got nothing. Any ideas would be appreciated; I drive to Dallas Tuesday.
Old May 6, 2000 | 09:35 PM
ggonc007's Avatar
New Member
Default Re: Engine dies cold at 75 MPH
Wow that is crazy, my new Passat B5 is doing that too. It you find out let me know
Gonc007@yahoo.com
Old May 7, 2000 | 06:03 AM
QCRAZY's Avatar
Default Have your return fuel lines checked out....
It sounds like your gas is getting too hot and causing cavitation at your fuel pump.
You should also have your charcoal canister checked out too, it could be "plugged"!! I would think that you may have a kinked return fuel line though.
Good Luck
Andrew
90 80Q
91 90
95 90Q
Old May 8, 2000 | 05:26 AM
92-100S's Avatar
New Member
If you find the solution to the problem, please post it, my 92 100s did the same thing a couple of times last summer as well as about 2 summers before<p>David Lipman
lipman@dean.com
mh644
37
Dec 18, 2019 10:02 PM
AudiQC
Audi allroad
May 29, 2014 12:09 PM
one5k
13
Mar 7, 2011 04:18 PM
Crispin
Audi allroad
Oct 9, 2010 06:44 AM
jlew39
9
Sep 15, 2006 06:36 AM
