Fuel Pump Buzzing - Any replacement tips
Old Jan 10, 2001 | 06:58 PM
Walt D's Avatar
New Member
Default Fuel Pump Buzzing - Any replacement tips
My fuel pump is very making a loud buzzing noise and I have a replacement pump and filter on the way. Any tips on installing the pump to avoid getting soaked in gas.
There is a hose from the tank to the pump. Do I just clamp this? Do have to drain the tank?
Anyone who has done this job and has some advice for me, I would really like to hear it.
Thanks, Walt
1988 Audi 90
185,000 miles
Old Jan 10, 2001 | 08:57 PM
QCRAZY's Avatar
Default Re: Fuel Pump Buzzing - Any replacement tips
You don't have to drain the tank. Just get all the "upstream" hoses off and get the fuel pump free....then swap the pumps as quick as you can at the gas tank hose. You won't loose that much gas!!!
It wouldn't hurt to have the tank on the low side!!!
Also, make sure the cars cold. You don't want to have any gas near warm exhaust parts!!
Good Luck!!
Andrew
90 80q
91 90
95 90q
Old Jan 11, 2001 | 05:12 AM
Gordie's Avatar
I recently replaced the pump on my 91'100 with not too much problem. As you know, access is through the trunk floor which eliminates having to drop the tank. Run the gas down as low as possible and make sure to disconnect the battery to avoid any sparks or static electricity. I got a real nice step-by-step guide from Chis Miller's web page(I think it came from there).
Old Jan 11, 2001 | 11:41 AM
QCRAZY's Avatar
Not the same....the 90 & 100 are miles apart on this!!!
budavid
Jun 8, 2009 03:41 PM
Stunna
1.8T Discussion
Oct 30, 2007 09:21 AM
BigTT
Mar 18, 2007 09:40 AM
Snowcar84
Oct 25, 2006 09:04 AM
piercejr
Audi 100 / A6 (C4 Platform)
Sep 2, 2003 05:14 PM
