Help! Window Problem
Old Jan 14, 2001 | 06:53 PM
ungringoloco's Avatar
Default Help! Window Problem
I have a 1996 Cabriolet. A few weeks ago, the driver side window would be touchy about going up. Now, none of my driver side window controls work, (neither does the passenger side control) but the center window switch (to lower all 4 at once) works on all windows but the driver side front window. I took the driver side window controls apart to ensure good contacts on the switches and even changed them around - still nothing - any ideas or am I Dealer-bound?? Thanks!!
Old Jan 15, 2001 | 07:52 AM
Silver Streakin''s Avatar
Member
Default Since I've been on this forum, you're the 1st Cab-welcome. it's sounds like you're dealer bound...
Electrical problems are difficult to answer. I think I'd be only guessing - sorry.
Old Jan 15, 2001 | 10:07 AM
Todd W's Avatar
Junior Member
Default Check the wiring in the driver's door.
The wiring from the car to the door goes through a rubber boot or similar. On old cars those wires can break from being flexed too many times. You can add a couple of inches to each wire, but it is tedious. Be sure to use multistrand wire of the smallest gauge possible - and keep the solder joints small.
Todd W
rkarsk
TT (Mk2) Discussion
Jan 22, 2021 02:57 AM
Cash68
Audi Original "S" Cars
48
May 5, 2009 05:06 PM
volcanob5
Jul 15, 2008 03:08 AM
thtguy
Jul 25, 2003 06:12 PM
the red pill
Aug 19, 2002 07:44 AM
