Snowflake next to outside temp.
Old Nov 9, 2000 | 03:24 PM
94-100CS-inWI's Avatar
New Member
Default Snowflake next to outside temp.
Here's a trivia question that has baffled me
since buying the car over a year ago...
When the outside temp gets around 38 degrees
a snowflake appears next to the temp. display.
I know it is a "warning" that the road conditions
could be slipery. Here's the weird thing:
Sometimes the flake is to the right of the temp.
and sometimes it is to the left. I have not
discovered a pattern (are the lights on, wipers,etc.)
Anyone know what makes the decision for right
or left display?
Thanks!
Old Nov 10, 2000 | 02:05 AM
ChuckH's Avatar
Member
hmmm, left means it's slippery, and right means you're screwed!
Old Nov 10, 2000 | 06:44 AM
QCRAZY's Avatar
Default It's in your owner's manual..(more)
..in case you don't have one, here's what it says!!
"At tempertures between 41F and 32F, a snowflake symbol will appear on the right side of the display. At temperatures between 32F and 23F, the snowflake will appear on the left side."
"WARNING"
"The snowflake symbol is to warn you that there may be ice on the road and that you should pay special attention."
"Ice can form or remain even at temperatures above freezing"
Hope this answers your question!!
It's not as complicated as you thought.
Andrew
90 80Q
91 90
95 90Q
Old Nov 10, 2000 | 03:00 PM
New Member
Default Re: It's in your owner's manual..(more)
Thank you, Andrew!
Now I feel really stupid! I could have sworn I
studied that manual -- it is where I learned that
the snowflake means possible ice.
Next time I will be like a carpenter (measure
twice, cut once)and read twice before posting
once!
Thanks again.
Old Nov 13, 2000 | 04:22 AM
ZCD2.7T's Avatar
Default Re: Snowflake next to outside temp.
I haven't seen the snowflake yet - must get cold up there in Cheeseland!!...... Glad you got your answer, though.
Tbone323
Audi A5 / S5 / RS5 (B9)
Feb 3, 2019 04:41 PM
arne rosdal
Q7 MK 1 Discussion
9
Apr 26, 2018 08:30 AM
gavin_gray
Audi 100 / A6 (C4 Platform)
Dec 5, 2005 04:22 PM
AUS A4
Dec 28, 2002 05:20 AM
adc
Oct 9, 2001 11:55 AM
