Been riding for one month and got my first punctured tire - can you plug these things?
Screw is lodged in front tire. Didn't even notice it while I was riding. I saw it this afternoon as I was admiring my bike. Do shops plug motorcycle tires like car tires, or will I need to buy a new tire?
not all the time
Motorcycle tires are very different than car tires - just look at the shape of them. Depends how far up the side it is.....also, I tend NOT to plug as a plug given out on a car is alot less painful then a plug giving out on a motorcycle.
There are issues.
Issue 1: Any plug negates the speed rating of a tire, i.e., a tire with a plug should only be run to 80mph regardless of manufacturer's speed rating.
Issue 2: There should only ever be one plug per tire quadrant.
Issue 3: There should only ever be two plugs total per tire.
Issue 4: Many motorcycle shops will not put a plug in a tire for you. Depending on your local shops, it may be DIY only.
I'd personally only use a plug in an emergency and replace the damaged tire ASAP.
It's up to you what your safety/life is worth. A blowout on a motorcycle is a vastly different situation than in a car.
Agreed. Do you really want to trust a plug...
when the only thing keeping you from sliding down the road is a contact patch only a few square inches big? Spend the money just so you don't have to worry about it.
