New Member Welcome Area We've gathered the info you need if you are new to the AudiWorld forums
Acceleration problem after engine replacement
Old 03-25-2019, 05:00 AM
Mikrowave's Avatar
Default Acceleration problem after engine replacement
Hello everyone,
i have a 2001 audi TT. Prior owner overtorqued mounting bolts leading motor to shake loose, timing belt to break and engine to blow up.
i have now replaced the motor, installed new clutch kit and reset throttle body and went thru ignition reset process. In addition i have replaced the diverter valve.
The problem is that the car does not accelerate properly. Starts up, sounds great but has very little power, as if throttle body remains closed. Very slow to get up to speed.
Can anyone recommend possible issues? I get no codes with cable.
Does chip need to be reset or what should be my next steps? I hate to pay a dealer or shop for something that ends up to be a simple solution.
THANK YOU!!
Mike
Old 03-25-2019, 02:20 PM
KevinGary's Avatar
There is very little activity on this board. You may want to post your question on the TT board.
smw
14
04-21-2008 02:41 PM
Mr. RighTT
14
01-18-2007 07:04 AM
antA4Q
12-21-2004 08:50 AM
Jeffc55
09-16-2001 07:49 PM
Quick Reply: Acceleration problem after engine replacement
