Go Back  AudiWorld Forums > Community Discussion > Off-topic Discussion
Reload this Page >
AWOT Diamond BT: what is an enhanced diamond? is it the same as a lab created diamond? good or bad?
Old 05-13-2004, 07:05 AM
BC(squared) is offline
Old 05-13-2004, 07:09 AM
Default I believe it is a diamond that has its imperfections filled with liquid glass.
Don't buy one if you ever plan to set it. When the mounting is heated to expand to hold the diamond, the glass will boil and the center of the diamond will explode. Yes Seriously.
This action isnt done in higher quality stones, VS1 and above. Its typically reserved to make an SI3 Stone a SI1 etc...
The Chef. is offline
Default *enhanced* -- sounds like a homegrown stone. An untrained naked eye can't tell the difference...
between synthetic/enhanced versus natural stone
2faS4u2pass is offline
Old 05-13-2004, 07:10 AM
AudiWorld Expert
Default They fill any flaws they can to enhance the clarity - it's still a 'real' diamond
but I'd pass and buy an unenhanced stone.
Most lab created diamonds are colored.
MattK is offline
Default Follow up: In fact I think we have had a long discussions about Diamonds before, you and I, if I
rememeber correctly, so you know my stance on Natual vs. Synthetic, Lab Created and Alterted Diamonds =)
Old 05-13-2004, 07:11 AM
Correct.
Old 05-13-2004, 07:14 AM
is it still real if it was *filled*? or 80% real 20% synthetic?
AudiWorld Expert
Default I spent a few year apprenticed to a jeweler
honestly lab created diamonds will probably be clear in a few years and I can't see how that won't obliterate or at least damage the real diamond market.
If I was buying a stone these days I'd consider an emerald even though it's not 'traditional' they're more rare and more likely to hold some value.
MattK is offline
Old 05-13-2004, 07:15 AM
Default FU: GIA has a seperate catagory for grading "filled" stones, and will still do it, but..
Any reputable larger jewler will not set a filled stone, do to the risk involved...
My Jewler, Baily Banks & Biddle will not set a Diamond of yours unless you have a GIA cert that goes with the stone that will insure not just measurements but also characteristics of the stone.
AudiWorld Expert
Default I'm sure the actual % of synthetic is very low but
I don't know the # and I'm sure it varies with every stone.
It's only used to fill surface occlusions (holes) so it can't be done on every diamond with crappy clarity.
MattK is offline
Quick Reply: AWOT Diamond BT: what is an enhanced diamond? is it the same as a lab created diamond? good or bad?
