Go Back  AudiWorld Forums > Community Discussion > Off-topic Discussion
Reload this Page >
i know SMG transmissions shift quickly (.2s, right?)...but how quickly can they shift two gears?
Old 07-27-2003, 01:23 PM
Elder Member
Default i know SMG transmissions shift quickly (.2s, right?)...but how quickly can they shift two gears?
i often accelerate fast and stop due to speed limit...so i shift 1-2-3-5. when you do a "double click" on an smg paddle, will both shifts take .4s combined, or will there be a delay?
CrappleZero is offline
Old 07-27-2003, 01:24 PM
AudiWorld Uber User
Default The Magnetti-Marelli system never "skips a gear"...
... except under very hard braking if you'd kill the engine, in which case it skips second to downhift from third to first and then to neutral as you come to a stop.
So the behavior you talk about is not normal driving behavior in an SMG vehicle.
Cameron is offline
Old 07-27-2003, 01:26 PM
Elder Member
Default i know they don't skip a gear
so it'd go 1-2-3-4-5...i was just wondering if there's any delay between shifts.
Old 07-27-2003, 01:27 PM
Member
Default Yes
.2s
whodkne is offline
Old 07-27-2003, 01:28 PM
Elder Member
Default yes what? there is a delay?
you people are confusing me.
if a 3-4 shift takes .2 sec, and so does a 4-5 shift....will a 3-4-5 shift take .4 sec or will it take longer?
Old 07-27-2003, 01:31 PM
Member
Default No
.2s
whodkne is offline
Elder Member
If what I've read is correct, if you double click fast enough, the computer will skip a gear.
Gop-Dogg is offline
Old 07-27-2003, 01:34 PM
AudiWorld Expert
double click... lol. sounds funny.
Jack in FL is offline
Old 07-27-2003, 01:40 PM
AudiWorld Uber User
Default Only if you click the second time before the first shift...
... has moved. Very hard to do, hence the 360 Challenge guys basically never double-click if you look at their cockpit videos.
Better to just shift one gear at a time. FYI, I tried to double-click downshifting several times in an F355 F1 and it never worked.
360 system has been updated a bit, though.
Cameron is offline
Old 07-27-2003, 01:41 PM
AudiWorld Uber User
Default It will take .4s unless you double-click in time.
Read my post in response to Gop-Dogg.
Cameron is offline
Quick Reply: i know SMG transmissions shift quickly (.2s, right?)...but how quickly can they shift two gears?
