1.8T Oil cooler install....>>
AudiWorld Uber User
<center><img src="http://images.fotki.com/v9/photos/7/7305/152444/DSCF0031-or.jpg"></center><p>Hit the Fotki link below and go to Oil Cooler for detailed install pics...Posted link for instructions
Steve<ul><li><a href="https://forums.audiworld.com/tt/msgs/701184.phtml">Oil Cooler X-post from the TT forum</a></li></ul>
Not installing an oil temperature thermostat ...
would make me a little nervous, especially in the Winter.
With a max oil temp of only 195 oF even on the track, I'd be worried about moisture accumulating in the oil and never getting boiled out.
Rest In Peace
I've got a 180 degree thermo and my oil temps stay pegged at 180 in street driving
even when it's 75+ degrees out. I'd imagine it would be substantially less than that without the thermo, and even lower in lower temps.
I'm with RYOUNG on this one - not a good idea to run it without the thermo. Methinks you'll be well out of the normal oil operating temps that it is designed for.
AudiWorld Uber User
It apparently doesn't matter with the 1.8.......>>
Non critical water feed that apparently is not dependent on looping.....(set-up recommended by Hallmotorsports)
