2.2L s4 transmission ??
anyone know how beefy the tranny are on a urs4? how much power can they hold? and can you laungh them and how high rpm do you usually launch before you think something would go?
I have dropped the clutch w/a 380whp 5 banger at 6000rpm but had a real good Sachs racing clutch
I have dropped the clutch on an rs2 tranny @ 6500rpm w/a 440whp 4 cylinder, same clutch. The URs4 tranny is bulletproof for the most part, but shifts like **** unless you put the JHM short shifter pieces in. Call Tim @ NEA, he is running a URS4 5 speed in a 500whp + car with no problems, Rs2 is a bit stronger. Buy a really good clutch.
Re: I have dropped the clutch w/a 380whp 5 banger at 6000rpm but had a real good Sachs racing clutch
can i get the email or contact info to tim, about him audi and the short shifter and all thanks alot
Eric, First gear go first because its very fragile. The S6 1995.5 tranny
had better 1st gear - longer and stronger. Im not 100% sure if the 1995 S6 had that better 1st gear too. But im 100% sure about the 95.5.
Your second option is the RS2 6spd. But thats some cash... + some good clutch.
Re: 2.2L s4 transmission ??
that tanny is as strong as the tranny used in the b5 s4. they also use 3 of the same gears, with the same part numbers. i also ran both transmissions in my car before.
runawayroger
01-08-2005 04:20 PM
Sia Bani
02-01-2004 07:42 PM
